Väga imelik mootor on näidatud selle 745i peal siin: http://www.bigarnie.co.za/cars/745i/files/SA745i.pdf
Minu arusaamist järgi oli 745i toodetud vaid 12 klapilise turbona või ma olen millestki valesti aru saanud? Aga siin tundub küll olevat M88 vabalthingav...
Imelik 745i
Imelik 745i
Ok, juba leidsin ise vastuse:
"A different 745i was built for the South Africa market, perhaps because the turbocharger on the European-market 745i could not be installed in right-hand-drive versions of the car. This car was fitted with the 286hp dual-camshaft 24-valve type-M88 Motorsport engine (with a Bosch ML-Jetronic fuel injection system) as used in the M1, M635i, and M5. 192 of these cars were built between 1984 and 1986, fitted with either an automatic transmission or a 5-speed 'sport' gearbox."
Iseenesest on see huvitav kuna ma ei teadnud et ka seda mootorit on koostöös automaatkastiga pakutud...
