Börsis (ja mujal) saadaval...
Seest on jh korralikum kui väljast.Väljast on puudu kundepoolne tuulesuunaja sealt stange alt,katus ja üldse terve kere on kaetud maru paksu saastakihiga- oli vist seisnud ka mingi ca 10 aastat vms.
Sisu oli küllaltki korralik muidu (must nahk). Taga need söögilauad on mõranenud lakiga vms,ühesõnaga tahab see masin kõvasti hoolt saada enne kui teid saab jälle vallutama hakata.
Suhtlesin kirja teel ühe lätlasega. Pakkus oma 520i 11/1986.
Et kui kellelgi mingi huvi peaks olema, siis selline:
http://i582.photobucket.com/albums/ss26 ... C04293.jpg
http://i582.photobucket.com/albums/ss26 ... C04292.jpg
http://i582.photobucket.com/albums/ss26 ... C04290.jpg
The cylinder head now is off to change one rocker arm and one valve (still nothing changed yet due less of time and $$ because i live in Riga and car is in Rezekne, wanted to build it back to ride, but the plans are changed now, because im still in e30 thing and can't afford 2 cars).
But bodyshell Overall in very good condition for its age, some rust on the thresholds under the rear doors, and maybe hood and front grill needs to be replaced (now in different color and not in best condition). Need to change both front seats but i bought 2 new seats already in Riga, with the same pattern 0096 Anthrazit). Need to get trunk trim all around, and i thing , the central panel (where instrument cluster goes) (some cracks on it)
The car is located near Rezekne, east Latvia. And, just now, my friend is there, who can show it if you are interested!
I want 500 eur for that car.
Huvitav lisanimetus, Exclusive Ei tea kas lihtsalt el.akende ja peeglitega on siis Comfort ja ilma el. lisadeta TrendKivunz kirjutas:http://www.auto24.ee/used/938159
Aga skoop on vägev, iga bemmiga võiks kaasas olla, nn. remondikomplektis, tasuta rellakas, millega skoope ja vedrusid tuunida
E24 börsis
Re: E24 börsis
Sama kuuene päris pikalt ka auto24-s müügis - http://www.auto24.ee/used/877864
Kes vaatamas käinud võiks lähemalt kommenteerida
Re: E24 börsis
HAIRIDER kirjutas:Sama kuuene päris pikalt ka auto24-s müügis - http://www.auto24.ee/used/877864
635BBN kirjutas:Käsutamis keeld LÄÄNE MAKSU-JA TOLLIKESKUS (24.09.2008 NR 13-5.3/16621) 25.09.2008
Aastake või vähem tagasi oli sel autol 2,7 turbo mootor.Sellest ka see scoop tõenäoliseltHAIRIDER kirjutas:Huvitav lisanimetus, Exclusive Ei tea kas lihtsalt el.akende ja peeglitega on siis Comfort ja ilma el. lisadeta TrendKivunz kirjutas:http://www.auto24.ee/used/938159
Re: E24 börsis
Mõlemad esitiivad paistavad piltidelt vaadates täitsa läbi olevat, see on juba ohu märk, et kogu kere vajab paikamist. Huvilised peaks enne ostu E24 keredetailide hindadega ja saadavusega tutvuma + siis muu kereremont ja kogu auto värvimine.HAIRIDER kirjutas:Kes vaatamas käinud võiks lähemalt kommenteerida
Pandava hinnaga klassic Leedus
Pandava hinnaga klassik Leedus:
http://auto.plius.lt/skelbimas/lengviej ... id-1936946
Mis kere see on selline? E? ?
Re: Pandava hinnaga klassic Leedus
E9, hind on küll sellisele klassikule väga hea!sillufromIV kirjutas:Pandava hinnaga klassik Leedus:
