Kuidas BMW originaal maki kood avada? Bavaria C II
Ostsin maki (bavaria C II) ja maki taga on väidetav kood, ei saa 100% kindel olla, et see õige on aga ei ava makki. Kas peale koodi sisustamise tuleb vajutada nuppu '>' ? Voi oskab keegi mõnd muud tarka nõu anda.
Electronic anti-theft Bavaria CII
The car radio is coded at the factory and so-
secured with theft. The four-digit
Code-No. is on the supplied
Car Audio Pass noted.
If the car radio from the power-
tion separately, it is when a new arrival
circuit will not work. After A-
want the device appears in the display
the writing code.
In this case, the four-digit code number.
about the station buttons 1 (thousands) to 4
(A) type.
With each tap of a button,
the value of the corresponding point
by one.
After correctly entering the code number. and
Acknowledge by pressing the right
Tuning the car radio button
functional.
An incorrect entry appears in the display
10 seconds ----.
Renewed after three incorrect entries are
the waiting time to 15 minutes.
Note: If the power supply cur-
interrupted during a waiting period begins
the waiting period again.
After another 16 false entries
made no further input, and
Display says OFF.
The decoding in this case only
by a BMW service against
Presentation of the car radio passport-CARRIED
be removed.
the writing code.
(A) type.
by one.
functional.
10 seconds ----.
Display says OFF.
be removed.
